BIOS Surface Pro 5 1796
Thank you! This worked for a while but after few minutes touchscreen stops working again. After a reboot it works again for about 2 minutes. Any ideas what could cause this?
need to check and test i am also not sure where the problem comes from
Can you do a fix for this BIOS file too? Here I get error code 14 on the Surface Touch Driver. Will try if this works for me.
Thank you.
please ignore the touch i will help fix it after you check the other components work perfectly first
I checked anything - no other problems than the touchscreen. Did already clean windows install but without success. Next I will try to use the surface recovery drive for a restore.
