BIOS Surface Pro 5 1796
This one didn't woked either. But after flashing back to the first one you sent me and another clean install of windows the touch worked perfectly. I don't really understand why but it's solved - thank you very much! :)
I've uploaded original bios file which was causing Surface logo to flash and turn off. I've flashed with the attached clean me region file and it works and turns on but Touch does not work and Intel Management Engine is showing 0.0.0.0 as version numbers.
I've tried different N-Trig modules, cables and LCD screen, same issue.
Thanks,
Great Forum!
Thanks,
Great Forum!
If you want the touch to work you need to have the original BIOS otherwise there will be no other solution
