ASUS Vivobook X556UV
ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    500GB/1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB SATA3 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x COMBO audio jack
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    ASUS SonicMaster Technology
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 3.42 A, 65 W
    Input :
  • Dimensions
    38.2 x 25.8 x 2.55 cm (WxDxH)
  • Weight
  • Security
    Kensington lock
  • Manufacturer Warranty
Asus X556UV_3.1.fz
it8995 ECROM.bin
X556UV 3.1 6th.BIN
CPU 6th
BIOS X556UV Rev 3.1
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    Solid State Drives:
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    Input :
  • Dimensions
  • Weight
  • Security
    Kensington lock
on this one i used the
ASUS VM591U X556UV I7 7th.BIN.zip and this file work ok , but gpu have yellow triangule (controler error)
model: asus k556u
pcb code: x556uv_mb rev 3.1
this one turn on with 0.27 amp consume and nothing happen
its administor password...plz help sir,administor password are removed...
this guy bios computer give image , it takes sometime to display image , but it requires bios admin password to carry further to see if this bios displayed well the gpu , so once again , can you help me out ?
also clear me of post #74 does turn on with good consume but no image !
asus k556UR
board x556uv 3.1
intel i7 7gen cpu
discrete gpu
You would have the new x556uv rev 3.1 i5 7200u
asus k556UR
board x556uv 3.1
intel i7 7gen cpu
discrete gpu
old bios error what? send i check
my old bios , start with 0.27 amps of consume and no display and no cpu phases runing . tryed with LBE fixing with the version on the site but same issue . anyway here it is .
original.bin
