ASUS Vivobook X556UV
ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    500GB/1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB SATA3 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x COMBO audio jack
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    ASUS SonicMaster Technology
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 3.42 A, 65 W
    Input :
  • Dimensions
    38.2 x 25.8 x 2.55 cm (WxDxH)
  • Weight
  • Security
    Kensington lock
  • Manufacturer Warranty
Asus X556UV_3.1.fz
it8995 ECROM.bin
X556UV 3.1 6th.BIN
Asus X556UV Rev 3.1
error ?
look you are doing is that .. you download file from asus .. and then add it to bios through hex editor ... now the issue is ... file size .. the original BIOS region and the one on Asus are of different size ... thats why bios is not working .. i am facing the same problem and here you are giving also same files
same problem what?
