ASUS Vivobook X556UV
ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    500GB/1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB SATA3 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x COMBO audio jack
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    ASUS SonicMaster Technology
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 3.42 A, 65 W
    Input :
  • Dimensions
    38.2 x 25.8 x 2.55 cm (WxDxH)
  • Weight
  • Security
    Kensington lock
  • Manufacturer Warranty
Asus X556UV_3.1.fz
it8995 ECROM.bin
X556UV 3.1 6th.BIN
before it is working properly after that bios flashing nvidia driver showing yellow, but the syetem original bios file is missing
one mr luice amaral having this same issue reported am also having this same situation
apple expert refers to the 7gen bios you have on first post , this one works but gives me the yellow triangle . we allready had this kind of issue in the past with the bios , and in the end i had a old original that i could fix , but for this board i only got the suposed original file that come with the board . unfrotunely we are a laboratory that works with stores from north to south of portugal , so many machines sometimes can come with previous fixes . so chek that out please really need this bios working
