ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
CPU 6th
BIOS X556UV Rev 3.1
- Processor
Intel® Core™ i3 6100U Processor, - Operating System
Windows 10 Home
Windows 10 Pro - Memory
DDR4 2133MHz SDRAM, 1 x SO-DIMM socket for expansion, up to 12 GB SDRAM - Display
15.6" (16:9) LED backlit FHD (1920x1080) Anit-Glaire Panel with 45% NTSC - Graphic
NVIDIA GeForce 920MX , with 2GB VRAM - Storage
Hard Drives:
500GB/1TB 5400RPM SATA HDD
2TB 5400RPM SATA HDD
Solid State Drives:
128GB/256GB SATA3 SSD - Optical Drive
Super-Multi DVD - Keyboard
Chicklet keyboard with isolated Num key - Card Reader
Multi-format card reader (SD/SDHC/SDXC) - WebCam
VGA Web Camera - Networking
Wi-Fi
Integrated 802.11b/g/n
10/100/1000 Base T
Bluetooth
Built-in Bluetooth V4.0 (Optional) - Interface
1 x COMBO audio jack
1 x USB 3.0 port(s)
1 x USB 2.0 port(s)
1 x HDMI - Audio
ASUS SonicMaster Technology - Battery
2 Cells 38 Whrs Polymer Battery - Power Adapter
Plug Type :ø4 (mm)
Output :
19 V DC, 3.42 A, 65 W
Input :
3/ 2 pin compact power supply system - Dimensions
38.2 x 25.8 x 2.55 cm (WxDxH) - Weight
2.3 kg (with 2 cell battery) with Battery - Security
Kensington lock
HDD User Password Protection and Security - Manufacturer Warranty
Asus X556UV_3.1.fz
it8995 ECROM.bin
X556UV 3.1 6th.BIN
