ASUS ROG GL553VD
GL553VD.jpggl553vd rev 2.0 fx53v
Asus GL553VD_2.0.fz
ECROM ROG GL553VD.bin
GL553VD IT8171 KB_pins=30 LEFT DOWN FLASH=56 PD0=2 PD1=11 PD2=16 PD3=8 PD4=17 PD5=15 PD6=19 PD7=1 BUSY=5 STB=13 AFD=3 INIT=10 SLIN=12 KSI4=9 KSI5=7
Asus GL553VD Rev 2.0 photo
Hello my friend,
i have a problem with this model. Please can you provide & check a good bios for me? Maybe build, clean or repair (i dont know)?
I flashed the bios.bin which you provided in the first thread, because system was freezing when installing fresh Windows 10.
Laptop has following issues:
- Slow reboot & slow shutdown (takes about 3 minutes)
- Nvidia GTX 1050 shows up in device manager with error 43
- Keyboard & backlight not working
I created a Backup.bin for you with AsProgrammer.
Thank you!
I know for Keyboard i need to flash IO, but i want to make sure bios is ok first before i do more work.. Thank you my friend!
can only know when you program other BIOS then compare the results, if two BIOS have same problem then BIOS is good.
Note that it is not possible to check good or bad BIOS from the BIOS file that can only be known after the programming store.
Yes i know, problem is that the bios chip was taken out before (flux on board) so i dont know what happend. Now laptop is running good, but has problems like i wrote before. May you check the file and maybe build?
Or should i skip this laptop and put it for parts? What do you think?
Thank you my friend.
Sadly no change, still takes a lot of time to shutdown & reboot, GPU also not ok.
Tried to flash ITE, on this mobo its IT ec it8176, i dont know if there is a difference with ec it8171 in pinout or something. Mainboard will not make a connection with programmer. Thats the end for this board.
Thank you my friend :)
