ASUS ROG GL502VM (7th Gen Intel Core)
Intel® HM175 Express Chipset (#Kabylake)
Schematic GL502VM
  • Processor
    Intel® Core™ i7 7700HQ Processor,
    Intel® Core™ i5 7300HQ Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro - ASUS recommends Windows 10 Pro.
  • Chipset
  • Memory
    8 GB DDR4 2400MHz SDRAM Onboard Memory, 1 x SO-DIMM socket , up to 16 GB SDRAM
  • Display
    15.6" (16:9) LED backlit FHD (1920x1200) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
    15.6" (16:9) LED backlit FHD (1920x1080) 120Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
    15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
  • Graphic
    NVIDIA GeForce GTX 1060 , with 3GB/6GB GDDR5 VRAM
  • Storage
    Hard Drives:
    1TB 5400RPM SATA HDD
    1TB 7200RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB/512GB SATA3 SSD
    Solid State Drives:
    128GB/256GB/512GB PCIE Gen3X4 SSD
  • Keyboard
    Illuminated Chiclet Keyboard
  • Card Reader
    Multi-format card reader (SDHC/SDXC/MMC)
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    10/100/1000 Base T
    Bluetooth
    Built-in Bluetooth V4.1
  • Interface
    1 x Microphone-in/Headphone-out jack
    1 x Type C USB3.1 (GEN2) Thunderbolt
    3 x Type A USB3.0 (USB3.1 GEN1)
    1 x HDMI
    1 x mini Display Port
    1X AC adapter plug
  • Audio
    Support Windows 10 Cortana with Voice
    ASUS SonicMaster Technology
  • Battery
    4 Cells 64 Whrs Battery
  • Power Adapter
    Plug Type :ø5.5 (mm)
    Output :
    19.5 V DC, A, 180 W
    Input :
  • Dimensions
    Tablet:
    390 x 266 x 23.5 mm (WxDxH)
  • Weight
    2.2 kg with Battery
laptop no display how to you can install ?
Good morning Thien,
The Clear me that you have done to me works fine on my mb, the only anomally is the fact that my nvidia don't install because the intel graphic card present on cpu is off. So the windows installs it as a microsoft basic graphic card.
Good morning Thien,
why above you say (Notebook starts without image to LCD with this ROM.) ?
Good Evening,
Check the CPU, in my case the nvidia was present but didn't instal because the the intel gpu is off.
Good morning, Rui.
Can you explain it in more detail?
Graph of intel / CPU off where? How did you turn it on?
So you got GTX turned on, driver installed and everything functional?
Thank you.
Good morning, Rui.
Thank you.
I can only explain if I have that computer in my hand and check it directly.
The cpu got the graphic card off.
Boa tarde Rui.
Sim, o meu pc liga com imagem!
Sim, tenho uma placa gráfica básica da Microsoft.
Sim, o ID do hardware é da Nvidia.
Então você me diz que a imagem que eu vejo está a ser gerada pela Nvidia, certo? Ok!
Como você fez para resolver o problema?
Obrigado.
Cumprimentos.
With the other bios the equipment have image for the lcd ...
Initial fault notebook start without image.
After programing to MAIN it started with image, but with the GTX graphic disabled.
What you mean other bios equipment helped to you?I have the same problem...
