ASUS ROG GL502VM (7th Gen Intel Core)
Intel® HM175 Express Chipset (#Kabylake)
Schematic GL502VM
  • Processor
    Intel® Core™ i7 7700HQ Processor,
    Intel® Core™ i5 7300HQ Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro - ASUS recommends Windows 10 Pro.
  • Chipset
  • Memory
    8 GB DDR4 2400MHz SDRAM Onboard Memory, 1 x SO-DIMM socket , up to 16 GB SDRAM
  • Display
    15.6" (16:9) LED backlit FHD (1920x1200) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
    15.6" (16:9) LED backlit FHD (1920x1080) 120Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
    15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
  • Graphic
    NVIDIA GeForce GTX 1060 , with 3GB/6GB GDDR5 VRAM
  • Storage
    Hard Drives:
    1TB 5400RPM SATA HDD
    1TB 7200RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB/512GB SATA3 SSD
    Solid State Drives:
    128GB/256GB/512GB PCIE Gen3X4 SSD
  • Keyboard
    Illuminated Chiclet Keyboard
  • Card Reader
    Multi-format card reader (SDHC/SDXC/MMC)
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    10/100/1000 Base T
    Bluetooth
    Built-in Bluetooth V4.1
  • Interface
    1 x Microphone-in/Headphone-out jack
    1 x Type C USB3.1 (GEN2) Thunderbolt
    3 x Type A USB3.0 (USB3.1 GEN1)
    1 x HDMI
    1 x mini Display Port
    1X AC adapter plug
  • Audio
    Support Windows 10 Cortana with Voice
    ASUS SonicMaster Technology
  • Battery
    4 Cells 64 Whrs Battery
  • Power Adapter
    Plug Type :ø5.5 (mm)
    Output :
    19.5 V DC, A, 180 W
    Input :
  • Dimensions
    Tablet:
    390 x 266 x 23.5 mm (WxDxH)
  • Weight
    2.2 kg with Battery
stupid questions
BIOS from you send and I just help clearme you need to know why ask me
sorry sir for the misunderstanding. And now the unit is working
@ThienBui clear giùm e file này. Bị lên hình chậm + ko nhận phím + wifi.
Up thủ 1-2 bios trong topic thì vẫn lên chậm + ko nhận wifi còn phím dùng bình thuong
file này lỗi ai xóa mất me region rồi,
thứ 2 file khác mà cũng ý thế thì không có clear me nào mà fix được,
tìm BIOS theo model ở trên miếng dãn khe ram mà test.
Ok, để e thử 1 vài file nữa coi sao.
Schematic GL502VM
  • Processor
  • Operating System
    Windows 10 Home
  • Chipset
  • Memory
  • Display
    with G-Sync
    with G-Sync
    with G-Sync
  • Graphic
  • Storage
    Hard Drives:
    Solid State Drives:
    Solid State Drives:
  • Keyboard
  • Card Reader
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x HDMI
    1X AC adapter plug
  • Audio
  • Battery
  • Power Adapter
    Output :
    19.5 V DC, A, 180 W
    Input :
  • Dimensions
    Tablet:
  • Weight
    2.2 kg with Battery
GL502VM-FY402T
i7-7700HQ
Late Display
ClearME Plz
