ASUS ROG GL553VD
GL553VD.jpggl553vd rev 2.0 fx53v
Asus GL553VD_2.0.fz
ECROM ROG GL553VD.bin
GL553VD IT8171 KB_pins=30 LEFT DOWN FLASH=56 PD0=2 PD1=11 PD2=16 PD3=8 PD4=17 PD5=15 PD6=19 PD7=1 BUSY=5 STB=13 AFD=3 INIT=10 SLIN=12 KSI4=9 KSI5=7
Asus GL553VD Rev 2.0 photo
gl553vd rev 2.0 fx53v.BIN.zip
Asus GL553VD_2.0.fz
ITE gl553vd.bin.zip
Asus GL553VD Rev 2.0 photo.zip
ASUS GL553VD.pdf
Asus GL553VD_2.0.fz
admin, do you know how to disable igpu in this board?
This asus works fine on battery, but shut down on adapter in 5 10 seconds. display comes on when we start the laptop and goes off in 5 to 10 sec. Even after display off all voltages are there. cpu and graphic ic heats fine even in off state. Any idea. On battery even for 2 hrs machine works fine
Pls provide nice solution.
replaced bios , panel . no change. when machine is on i had taken those voltages. they are same when display goes off. cpu is on throughout.
pls provide some solution
mình đang gặp 1 con bị chập io, mua con khác về thay ko đc, ad hướng dẫn cách câu dây để nạp con ec đc ko? mình dùng con rt809h mà cái cáp phím nó ko vừa chắc phải câu dây. @ThienBui
