BIOS Surface Pro 5 1796
Hey, I have a problem with Bios, i did charge new one in chip but touchscreen don't work, the old bios i saved just dont let me launch windows, when i try power on Surface Pro 5 windows logo jump for 3~seconds and then just turn off. As i see you know how to fix this kind of problems with bios so i just upload you the orginal one with problem.
can you fix the bios?
There is only the logo for a few seconds and it turns off. I tried the other bios above but it's the same
Surface 1796
others had the same faults and after uploading the new bios they managed to start the computer. Why do you say it's not bios fault?
if it's a BIOS error, then load the BIOS above it will work and I only help fix touch loss or display delay
And you, above you said other BIOS programmers have the same problem, it's not a BIOS problem
ok i thought other bios wouldn't work that well and that old bios is needed. I am looking for the fault elsewhere then. thanks
