Surface Book 1832 test ok.bin
sir clear paswrd
Hello. Pleas eneed repair this bios, no display model m1023323-006. thanks
hi please clear password
book 1 x910513-011
it shows that the BIOS you provided is not the original BIOS, this is your problem with Surface if you lose the original BIOS the touch will not workpassword is cleared but touch not working now
where is your BIOS first? and send me the induction working video showits original bios and touch was working.but not working on bios that you sent me
Hi, my Surface doesn't start. I tried one bios from here and it works but the touchscreen doesn't work. Can you fix my bios?
it shows that the BIOS you sent is not the original BIOSThanks but on this bios the touchscreen still doesn't respond for touch.
It is the original bios I read it by myself from the Surface and it wasn't open by anyone before. So it must be original bios.it shows that the BIOS you sent is not the original BIOS
clear me xong nó cũng mất cảm như như vậyClear giúp mình con này với bạn mấy con clear trên chép vô mất cảm ứng
Máy bị báo mất cắp, sài 1 tí báo mất cắp bạn, trước bios này mình gửi qua bạn nhầm ở bios dell, nhưng bạn clear cho mình rồi thì mất cảm ứng á bạnclear me xong nó cũng mất cảm như như vậy
quan trọng bios này bị cái gì ???
thì nói rồi màclear me xong nó cũng mất cảm như như vậy
