Surface Book 1832 test ok.bin
that could be the problemI did use another screen, does that matter?
I can't use old screen because it is broken. Is there a way to make new screen working with touch when not having the IO board from original screen?that could be the problem
you need test again bios lock
Does the BIOS lock work with the new screen before unlocking?I can't use old screen because it is broken. Is there a way to make new screen working with touch when not having the IO board from original screen?
I don't know, because screen was broken.Does the BIOS lock work with the new screen before unlocking?
It's very difficult and I don't have a solution yetI don't know, because screen was broken.
So, my question whas, is there a way to make new screen working with touch when not having the IO board from original screen. Do you know?
It is indeed very difficult. I even took of de eeprom from IO board of screen to check if there is something in the code that can be found back in the bios bin from tablet motherboard.It's very difficult and I don't have a solution yet
not sure problem bios, you need try BIOS on top beforeSurface Book 1832
please fix POWER ON AFTER OFF
Do you have BoardView and Schematicnot sure problem bios, you need try BIOS on top before
UnavailableDo you have BoardView and Schematic
error what ?hi tien, When I update the drivers it starts to work poorly and give graphic errors, can you please try to solve it? thank you
surface book 2 1832 i5 8th gen
it crashes, and gives graphical errors.error what ?
send photo i check
buiiss7.zipSurface book 2, có nguồn không hình. nhờ ad fix giùm em với ạ
xóa pass bios dùm ad
máy vẫn chạy bình thường ?file backup máy sf book 2 mà sao hiện thông tin surface pro 6 zậy ad
máy vẫn chạy bth a mà vào bios vẫn hiện surface pro 6máy vẫn chạy bình thường ?
mình kiểm tra trong bios vẫn là Surface_Book_1832 mà
Bỏ một ly cà phê hôm nay.
