Intel ME Region
Intel ME Region là gì:
ME System Tools
ME Region Series:
HM55 ME Asus 1208.bin
HM55 ME Lenovo 1208.bin
HM55 ME Samsung 1203.bin
HM55 ME Sony 1194.bin
HM55 ME Sony 1208.bin
HM55 ME Toshiba 1194.bin
HM57 ME Sony 1052.bin
HM65 ME Acer 1197.bin
HM65 ME Lenovo 1088.bin
HM67 ME Dell 1197.bin
HM76 ME Toshiba 1410.bin
HM77 ME Sony 1265.bin
UM67 ME Acer 1119.bin
>> FLASH IMAGE TOOL
used the file what you posted beginning of the thread but with that board not turning on I have the working bios with that turn off the board after 30 min, slj8e chip Chang due to no display. suspicious about me region
you need i help what ?
I tried one more time it woks my problem is not with me region your file is working Thanks..
