Intel ME Region
Intel ME Region là gì:
ME System Tools
ME Region Series:
HM55 ME Asus 1208.bin
HM55 ME Lenovo 1208.bin
HM55 ME Samsung 1203.bin
HM55 ME Sony 1194.bin
HM55 ME Sony 1208.bin
HM55 ME Toshiba 1194.bin
HM57 ME Sony 1052.bin
HM65 ME Acer 1197.bin
HM65 ME Lenovo 1088.bin
HM67 ME Dell 1197.bin
HM76 ME Toshiba 1410.bin
HM77 ME Sony 1265.bin
UM67 ME Acer 1119.bin
>> FLASH IMAGE TOOL
yes. i guess its problem with motherboard. first i thought the problem is intel region. but the files you send didnt work. so what could be the problem? do u have any idea?
you need get shematic and check all volt in-out check if all its ok
internal damage beetwen layers maybe,
have check the external video signal ?
have check power on laptop without connected ldvs flexor cable ?
not these too.
in first times my laptop was shutting down in 2-3 hours cause of heating problems.
i used it like this for a while with high temperatures.
after a while, as i said it before, now it shuts down in 1-2 minutes. and i couldnt fix it somehow
