HP 15-DB0337UR EPV51 LA-G078P Rev: 1.0
HP 15-DB0337UR(4RK85EA) EPV51 LA-G078P Rev: 1.0
084AC 8MB and ENE
084AE 16MB and ENE
HP 15-DB LA-G078P EPV51_Rev1.0_2018.03.09_UMA photo
LA-G078P r1.0.cad
Hello. I have a hp 15-db0101nl (motherboard model EPV51 LA-G078P rev. 1) that turns on, but suddenly a screen always appears which I am attaching in the photo. I thought it might be a corrupted bios file. I am attaching that too. Thank you
I think no problem bios
but if you read the file I sent you, can you tell if the file is damaged? so I rule out the problem 100% if possible. thank you
I can only check its data if the BIOS is bad or good can only know after programming on the laptop
but model this use AMD chip I sure 100% AMD chip have problem
