Dell Latitude 3480 Taos 16852-1 D5FVH
Dell Latitude 3480
BIOS Taos 16852-1 D5FVH UMA, MEC1416-NU
Dell Latitude 3480/3488
Schematics Latitude 3480 3488 3580 16852-1 2-7 taos_kbl-u_a00_1223_1
boardview Dell Latitude 3480 - Taos - 16852-1 Boardview (.CAD).cad
16852-1.brd
16852-1 TOP.pdf
16852-1 BOTTOM.pdf
Thank you for your previous effort with the Clean ME, but unfortunately, it did not fix the problem. The laptop still blinks 3 Amber and 3 White.
To isolate the issue, I flashed a completely different tested working dump on this board. The laptop turned on and gave a display immediately. This proves that my hardware is 100% fine, but the BIOS Region (or Descriptor) in my original file is deeply corrupted, which is why a simple "Clean ME" on the old file failed.
Could you please build a new file for me? Please use a known working clean BIOS region and transfer my original DMI data, Service Tag, and Windows Key from my attached original backup into it.
Here is my original corrupted backup again (Attached).
Thank you for your cooperation!
Hi ThienBui,
My laptop model is actually Latitude 3580. On the multi-platform screen, I correctly selected Latitude 3580 and pressed Enter.
Right after making the selection, the laptop went into a continuous shutdown loop (turns on for a few seconds, fan stops spinning, then cuts power completely).
This confirms that the ME Region / Thermal configuration for the 3580 profile in this file (⁠builds7.zip⁠) is incompatible or corrupted. Could you please fix the ME Region specifically for the Latitude 3580 configuration on this Wistron 16852-1 board?
Thank you for your help!
NO DISPLAY FIX PLEASE
  • 16852-1 JSSI.BIN
    16852-1 JSSI.BIN
  • Technical file information BIOS / firmware dump
    Technical attachment 16852-1 JSSI.BIN. Resource type: BIOS / firmware dump. Motherboard code: 16852-1. SPI flash capacity: 16 MB. Verify the exact model and board revision before programming or repair work.
    Motherboard
    16852-1
    Memory / flash device
    SPI NOR flash · 16 MB
    File type
    BIN · 16 MB
    SHA-256
    18eadbe6e41a545ddb32c455667ad2c31556c70e05f5488e17effbeb4990ec76
    Download access
    Paid membership required
    Community verification No verified downloader ratings yet.
  • Latitude 3480 16852-1 JSSI_builds.zip
  • Technical file information BIOS / firmware dump, BIOS Builds
    Technical download for Dell Latitude 3480. Resource type: BIOS / firmware dump, BIOS Builds. BIOS build and DMI restoration service: device identity data and firmware regions should be checked before programming. Motherboard code: 16852-1. SPI flash capacity: 16 MB. The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
    Manufacturer
    Dell
    Model
    Latitude 3480
    Motherboard
    16852-1
    File type
    ZIP · 5.7 MB
    Archive entries
    1
    SHA-256
    39d1766c7b65f30d01b65db4cead056df71310ffa72996cae2262c296ec0536c
    Download access
    Show archive contents
    • 16852-1 JSSI_builds.bin
☕ NEW • PAY IN VND
1 Ly Cà Phê
49k / Ngày
Bỏ một ly cà phê hôm nay.
Mở khóa ngay
