Asus X550VX
I have the same problem, probably pch issue because change KBC don't solve
If you have problem to read kbc it's very important that the original bios is in use, with a
dump there is a problem to read kbc with vertyanov programmer I don't know with other programmer but I think it's the same.
Someone can confirm that the "most of the LEDs are on without a bios post" is a problem of pch?
hi friend! Have you resolve the problem Asus 30 min turns off. I have the same problem after i change the HUB
Hi,
I need bios file for Asus K550VX i7 8GB onboard RAM.
After bios update notebook is not working.
Actually when I insert power cord or battery, 4 leds (power, wifi, caps lock, num lock) switch on. If I keep pushing power button, nothing happen.
No video, no fan.
Previous bios was X550VX.302 , 05/04/2017
I tried with no success the bios at https://vinafix.com/attachments/clear-me-bin.85573/ . No display; power led and caps lock fixed light; battery led blink two time, pause, blink two times again. All leds are green.
I kindly ask if you have also a bios modded with deactivated onboard RAM.
Thanks
Hi,
No video, no fan.
Thanks
4ram or 8ram use same BIOS
