send old BIOS I help buildsi need Bios surface Pro LTE Model 1807 , Code mainborad M1011229-019 , Thank you
Old biossend old BIOS I help builds
with surface need to have original BIOS otherwise it will lose touch when programming other BIO
Old bios
please help rebuild
builds3113.zipplease help rebuild M1011229-019
Hi ThienBui, thanks for doing it but it doesn't work; 5 seconds on and off. The serial number in that bios is from a Surface Book 2, could it be for that? Thank you, regards.
does it mean that the bios you sent is not the correct model for this topic?Hi ThienBui, thanks for doing it but it doesn't work; 5 seconds on and off. The serial number in that bios is from a Surface Book 2, could it be for that? Thank you, regards.
Hi, the bios that I sent you is the original of the Surface Pro 5 LTE M1807. The builds3113.zip you sent me has another serial number (according to Microsoft it belongs to a Surface Book 2 I7), with it the Surface stays on for only 5 seconds and turns off. Thanks.does it mean that the bios you sent is not the correct model for this topic?
Surface_Pro_1807does it mean that the bios you sent is not the correct model for this topic?
Hi, sorry to bother you again but the touch screen doesn't work; control panel mentions device not connected. I don't know if I'm correct but I've seen people talking that it's related to Intel ME Region, would it be possible?Surface_Pro_1807
try this
If you don't have the original BIOS or the original BIOS is completely faulty, you can't fix the touchHi, sorry to bother you again but the touch screen doesn't work; control panel mentions device not connected. I don't know if I'm correct but I've seen people talking that it's related to Intel ME Region, would it be possible?
Another very interesting thing; now it turned into Surface Pro 6, it was 5 and now 6. I suppose it interfered with some hardware since it takes a good few seconds to enter UEFI.
Attach a photo.
Thank you, regards.
HI i need bios please or can you fix it...error works two seconds and turn off..View attachment 192841Surface Pro LTE - Calgary_LTE .pdf
builds99.bin.zipHI i need bios please or can you fix it...error works two seconds and turn off..
SURFACE 1807 M1011229-019 REV 4.3
