Ask Surface go 2 1926 recovery no peripherals no touch
Question & Answer Forums
lcross
This surface was restarted mid update, now it only boots in recovery mode, the thing is that it no longer recognizes peripherals, the usb c port doesn't work (not a hardware issue, usb port worked before this happened) already tried to insert with a usb c to usb a adapter:keyboards mouse, usb memory, and nothing works, touch is also unresponsive, surface keyboard also don't work, when booting in bios same thing and touch is unresponsive, touchscreen is good it was already tested on another device, i tried also to load a fresh copy of windows on a usbc external ssd and still it doesn't boot with it, even i loaded win 11 on a micro sd and it doesnt boot with it either, any sugestions?, this motherboard is a replacement that i order it worked perfectly for a couple of weeks until now
