Schematics Lenovo Ideapad 3 15IAU7- NM-E341
Lenovo Ideapad 3 15IAU7- NM-E341 BoardView
NS-E342.tvw
NM-E341REV1.0.tvw
JKCN42WW
NM-E341 Rev 0.1.pdf
Schematics
NM-E341 KB_pins=34 (JKB1) LEFT DOWN 08MM PD0=20 PD1=16 PD2=14 PD3=9 PD4=13 PD5=17 PD6=10 PD7=12 BUSY=23 STB=15 AFD=26 INIT=19 SLIN=18 KSI4=22 KSI5=21 FLASH=256 CHIP=IT8227VG-256
Several issues were fixed, like not shutting down before and taking a long time to show a display. But now, it turns on and boots only when I do a CMOS reset. If it keeps the settings and I press the power button, the power LED flashes but there is no display/POST.
¡HOLA! ¿PODRÍAS AYUDARME A DESHABILITAR LA MEMORIA RAM, POR FAVOR?
JV473&JV573&JS478&JS578&JS778 NM-E341 REV 1.0 SIN IMAGEN, SOLO SE ILUMINAN LOS LED DEL TECLADO
Solo te digo que apagues la RAM, tienes que saber lo que estás haciendo, como dijiste, parece que la placa base no tiene
I'm just telling you to turn off the ram, you have to know what you're doing, like you said, it looks like the motherboard doesn't have RAM
Necesito desactivar la RAM integrada para usar el módulo de RAM extraíble. Con el archivo que me has proporcionado, solo enciende y se apaga inmediato.
