Intel ME Region
Intel ME Region là gì:
ME System Tools
ME Region Series:
HM55 ME Asus 1208.bin
HM55 ME Lenovo 1208.bin
HM55 ME Samsung 1203.bin
HM55 ME Sony 1194.bin
HM55 ME Sony 1208.bin
HM55 ME Toshiba 1194.bin
HM57 ME Sony 1052.bin
HM65 ME Acer 1197.bin
HM65 ME Lenovo 1088.bin
HM67 ME Dell 1197.bin
HM76 ME Toshiba 1410.bin
HM77 ME Sony 1265.bin
UM67 ME Acer 1119.bin
>> FLASH IMAGE TOOL
ok ..I really needed this, but possible to temporarily help me. I want the appropriate file for this model because the file that you gave me is not the same size
i need 1.7mb
11.0.0.1160 Appropriately with this model Inspiron-15-5559-AAL15 LA-D071P REV;1.0(A00) And size 1.7MB
