iMac (Retina 4K, 21.5-inch, 2017) 820-01069-B
A1418 EMC3068
A1418 EMC3068
plz boardviewiMac (Retina 4K, 21.5-inch, 2017) 820-01069-B
A1418 EMC3068
Unavailableplz boardview
builds như nào? chỉ mình vớiBuil lại file này giúp em với anh.
iCloud xoá rồi còn gì nữa. kiểm tra lại xem yêu cầu bao nhiều lần rồi.file này ko boot ,file của anh lên hình ok cài thì dính icloud anh ơi.
HELP PLEASE,
AFTER UPDATE IT DAMAGED,
REPAIR PLEASE
that can't say that the BIOS is faulty and i can't check from biosthe mac is not turning on with the bios file that you send me. the bios that i send you before. Wont boot to system and restart. the imac was upgraded to ventura and just after that, the problem beigin. Now the imac is not booting with any external or internal HDD
Hello, can you clear ME, please?
clearme ?Hi. Can you clear Me this?
yesclearme ?
why clearme?This file still has an error and doesnt work as the original. Apple logo and off.
The one on the top of the forum worked but it is not clean ME I think. It says INITIALIZED. Can you clean ME this one? Thanks.
Why? Really? Because it has to be cleanMe Region otherwise it gives many different problems.why clearme?
is there delay display ??
I think it's your imagination.Why? Really? Because it has to be cleanMe Region otherwise it gives many different problems.
In my case a bit slow graphics on UEFI then booted fine and installed OS and worked for hours. Then 3rd or 4th boot start giving problems, finally NO BOOT again.
FYIO: No clean MeRegion can lead to a number of issues, including:
A long POST delay (prior to Apple chime and boot menu)
The system hanging indefinitely on its loading screen with the Apple icon and a partially or even fully filled bar
The system being able to boot into Windows/Linux/etc. but never successfully into MacOS or any MacOS installers
The system being able to boot into EFI ASDs but not OS ASDs
Freezing or kernel panics while booting macOS
Error messages during verbose boot mode resembling "busy timeout[0], (60s): 'IGPU'"
The fan always running at full speed
Hard, spontaneous shutdown after 30 minutes
No POST situations
More obscure, fringe symptoms like the webcam not working on some Mac boards.
