BIOS hp probook 430 g7 430 G6 part number DA0X8LMB8D0 REV D
with the original bios 128.bin, the PC always restarts, reaches the logo and restarts, with the bios below that I attach it works but starts slowly.
Please make one video late display and show laptop work normal after delay I check
try more bios other and check hardware
every time a bios doesn't work you always respond the same way, the pc works perfectly, it just starts up 40 seconds late, you don't know what to say and you always respond, take videos that I check, check the hardware.
I have supported you with the cls above but you said it doesn't work so I have to confirm to see if what you said is correct and the device still works as before.
With the last bios you gave me, the PC got worse, you don't know how to solve it and you give hasty answers, saying untrue things.
Every time the BIOS doesn't work, you always say the same thing, CHECK HARDWARE, because you don't know how to fix it.
a classic slow boot problem of 40 seconds, always due to the bios needing to be erased, what does hardware have to do with it.
I checked the hardware, the PC is ok, it only has a 40 second delay which is due to the bios, it has already done and sent you the video, you just have to clean the bios.
I request video why not provided ??
Do you feel like there are a lot of comments on this topic? as it will affect other members
Ho richiesto un video perché non viene fornito?
Pensi che ci siano molti commenti su questo argomento? poiché influenzerà altri membri
The video has been attached, now it says I don't require it? Why do you say I didn't require the video? I'll put it back here again.
