clearme not fix no display, you need try one BIOS anothernow it turns on with black screen, try to fix bios clear me.
ok solved!, I took the mee bios attached and the whole pc works, only the USB port that I replaced does not work, it always remains blocked at 5 v, it does not go up to 20 v, you need to understand if these chips have internal code to do go up to 20 v.clearme not fix no display, you need try one BIOS another
I entered the old bios and the notebook turns on after several times that I press the power button, can you fix the defect in the bios?clearme not fix no display, you need try one BIOS another
How do you know it's a bios error?I entered the old bios and the notebook turns on after several times that I press the power button, can you fix the defect in the bios?
because if I put another bios the pc works and turns on the first time I press power, with a different bios the pc works but the bitlocker protection is activated.How do you know it's a bios error?
So back up the data then reformat the disk so there will be no bitlock even if I help build the bitlock will still appear like you use other BIOSbecause if I put another bios the pc works and turns on the first time I press power, with a different bios the pc works but the bitlocker protection is activated.
with the old bios I have to turn on the pc several times to make it work, after several attempts the pc turns on and runs smoothly without the bitlocker protection, then when I turn off the pc to turn it back on again I have to press the power button several times.
I need boardview files for 7390 LA-H931P. Can you help me finding the files, please?So back up the data then reformat the disk so there will be no bitlock even if I help build the bitlock will still appear like you use other BIOS
Unavailable boardviewI need boardview files for 7390 LA-H931P. Can you help me finding the files, please?
yes rtheer not a BIOS problem try another bios to compareplease clear cannot install os during install give blu screen
la-h931p
clear me this
I check it not right dell XPS ?hi sir repair my org bin no display plz repair this bios
I check it not right dell XPS ? sir this is the orignal bin la-h931 plz repair
chính nó đang bị thì builds nó cũng y vậy thôi bạnbuild giup em kich tat . fife khac len nhung mat cam ung
la-h931p
plz rebuild no power
