LA-H931P.pdf
mee.zip
LA-H931P.pdfi need la-h931p schematic and boardview
you need try one bios new beforeHello
Dell La-H931p no power at all . Charger have got 20V and current is 0.05A all voltages are on rails . The motherboard have got 5v , 3.3v , 1v , 1.8v , 20v , 7.6v on rails . There is no short circuit on board .
Is seems to be the issue is bios or EC
There is no any light or action for turning on with or without battery .
This is the backup from the bios of this laptop . Needs to replace EC file and fix the file .
Thank you
plz build my bios no display
try adding another bios if same problem then need to check hardwarenot working power on after 4 to 5 second power off
clearme not fix no displayplz clear me no display
clearme not fix blue screenHi, clear ME please? i have a blue screen all time
plz rebuild admin no power thanks
bác fix giúp e bị treo logo
It is possible that the circuit is damagedHi friends I have this dell with the chip tps65982dd U20 motherboard position shorted is hole, I made the replacement with a new chip, now the USB port is stuck on 5v and does not rise to 20v, the question, but this chip have code inside? do they need to be replaced by a donor motherboard?
now it turns on with black screen, try to fix bios clear me.It is possible that the circuit is damaged
