ASUS Vivobook X556UV
ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    500GB/1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB SATA3 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x COMBO audio jack
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    ASUS SonicMaster Technology
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 3.42 A, 65 W
    Input :
  • Dimensions
    38.2 x 25.8 x 2.55 cm (WxDxH)
  • Weight
  • Security
    Kensington lock
  • Manufacturer Warranty
Where could I find a BIOS to download for:
Sticker Model: Asus R558UA-DM966T
Motherboard: X556UV_MB 3.1
CPU: Intel i5 - 7200U 7th Gen
Integrated graphics Intel 620 HD
SSD 256GB
Screen 1080p Matt
I am using C341A with AsProgrammer to copy the BIOS into the chip.
I have tried all the Bios files on this thread, but either the screen does not work, or the fan is running on max speed all the time.
Thank you for your help!
SSD 256GB
Screen 1080p Matt
no display have many problem not only BIOS
old bios error what ?
Thank you for the reply.
Old BIOS was corrupted when doing an update. (I have attached it)
The screen works with some BIOS files, but with some it doesn't.
