ASUS Vivobook X556UV
ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    500GB/1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB SATA3 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x COMBO audio jack
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    ASUS SonicMaster Technology
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 3.42 A, 65 W
    Input :
  • Dimensions
    38.2 x 25.8 x 2.55 cm (WxDxH)
  • Weight
  • Security
    Kensington lock
  • Manufacturer Warranty
need asus x556uv rev.:3.1 prosesser i5 7th gen bios plz
not work showing blank display
plz help me sir
x556uv rev 3.1
core i5 6th gen
this mothboard was no power ,then i write bios from this site ...then power in but ddr volt. not come ...but ddr ic ok ...i write more bios but same problem .
plz give solution.
bellow old bios
