ASUS VivoBook Max X441SC
Boardview Asus X441SC 2.1.fz
  • Processor
    Intel® Pentium® Quad-Core N3710 Processor,
    Intel® Celeron® Dual-Core N3160 Processor,
    Intel® Celeron® Quad-Core N3160 Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Integrated Intel® CPU
  • Memory
    DDR3L 1600MHz SDRAM Onboard Memory, up to 4 GB SDRAM
  • Display
    14.0" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
    14.0" (16:9) LED backlit FHD (1920x1080) Glare Panel with 45% NTSC
    Support ASUS Splendid Technology
  • Graphic
    NVIDIA GeForce 810M , with 1GB VRAM
  • Storage
    Hard Drives:
    500GB 5400RPM SATA HDD
    1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
    Multi-format card reader (SD/SDHC)
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    10/100 Base T
    Bluetooth
    Built-in Bluetooth V4.0
  • Interface
    1 x COMBO audio jack
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    Built-in Stereo W Speakers And Microphone
    ASUS SonicMaster Technology
  • Battery
    3 Cells 36 Whrs Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 1.75 A, 45 W
    Input :
  • Dimensions
    348 x 242 x 27.6 mm (WxDxH)
  • Weight
    1.75 kg
X441SC.303.bin.zip
Asus X441SC_2.1.fz
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    10/100 Base T
    Bluetooth
  • Interface
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    Input :
  • Dimensions
  • Weight
    1.75 kg
sir do you have boardview and schematic for x441sc rev. 2.1?
I have same problem no display.
On power supply show only 0.160 Amp.
i was flash bios all file in this page
i was change ic bios
i was flash kbc on this page
i was remove lan ic
i was remove sound ic
i chek all pl is show value normal.
anybody cab help. Thanks
i was remove lan ic
old bios error what? you have save send i check.
