ASUS VivoBook Max X441SC
Boardview Asus X441SC 2.1.fz
  • Processor
    Intel® Pentium® Quad-Core N3710 Processor,
    Intel® Celeron® Dual-Core N3160 Processor,
    Intel® Celeron® Quad-Core N3160 Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Integrated Intel® CPU
  • Memory
    DDR3L 1600MHz SDRAM Onboard Memory, up to 4 GB SDRAM
  • Display
    14.0" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
    14.0" (16:9) LED backlit FHD (1920x1080) Glare Panel with 45% NTSC
    Support ASUS Splendid Technology
  • Graphic
    NVIDIA GeForce 810M , with 1GB VRAM
  • Storage
    Hard Drives:
    500GB 5400RPM SATA HDD
    1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
    Multi-format card reader (SD/SDHC)
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    10/100 Base T
    Bluetooth
    Built-in Bluetooth V4.0
  • Interface
    1 x COMBO audio jack
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
    Built-in Stereo W Speakers And Microphone
    ASUS SonicMaster Technology
  • Battery
    3 Cells 36 Whrs Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 1.75 A, 45 W
    Input :
  • Dimensions
    348 x 242 x 27.6 mm (WxDxH)
  • Weight
    1.75 kg
X441SC.303.bin.zip
Asus X441SC_2.1.fz
pinouts based on vertyanov jig and svod
X441SC KB_pins=26 PD0=2 PD1=11 PD2=16 PD3=8 PD4=17 PD5=15 PD6=19 PD7=1 BUSY=5 STB=13 AFD=3 INIT=10 SLIN=12 KSI4=9 KSI5=7
I have same problem no display.
On power supply show only 0.160 Amp.
i was flash bios all file in this page
i was change ic bios
i was flash kbc on this page
i was remove lan ic
i was remove sound ic
i chek all pl is show value normal.
anybody cab help. Thanks
same problem and install the one you have here and it's the same, here my backup if you can help me verify it
backup.BIN
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    10/100 Base T
    Bluetooth
  • Interface
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    Input :
  • Dimensions
  • Weight
    1.75 kg
Please clearme sir
X411SC REV 2.1.bin
