ASUS ROG GL502VM (7th Gen Intel Core)
Intel® HM175 Express Chipset (#Kabylake)
Schematic GL502VM
  • Processor
    Intel® Core™ i7 7700HQ Processor,
    Intel® Core™ i5 7300HQ Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro - ASUS recommends Windows 10 Pro.
  • Chipset
  • Memory
    8 GB DDR4 2400MHz SDRAM Onboard Memory, 1 x SO-DIMM socket , up to 16 GB SDRAM
  • Display
    15.6" (16:9) LED backlit FHD (1920x1200) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
    15.6" (16:9) LED backlit FHD (1920x1080) 120Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
    15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    with G-Sync
  • Graphic
    NVIDIA GeForce GTX 1060 , with 3GB/6GB GDDR5 VRAM
  • Storage
    Hard Drives:
    1TB 5400RPM SATA HDD
    1TB 7200RPM SATA HDD
    2TB 5400RPM SATA HDD
    Solid State Drives:
    128GB/256GB/512GB SATA3 SSD
    Solid State Drives:
    128GB/256GB/512GB PCIE Gen3X4 SSD
  • Keyboard
    Illuminated Chiclet Keyboard
  • Card Reader
    Multi-format card reader (SDHC/SDXC/MMC)
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    10/100/1000 Base T
    Bluetooth
    Built-in Bluetooth V4.1
  • Interface
    1 x Microphone-in/Headphone-out jack
    1 x Type C USB3.1 (GEN2) Thunderbolt
    3 x Type A USB3.0 (USB3.1 GEN1)
    1 x HDMI
    1 x mini Display Port
    1X AC adapter plug
  • Audio
    Support Windows 10 Cortana with Voice
    ASUS SonicMaster Technology
  • Battery
    4 Cells 64 Whrs Battery
  • Power Adapter
    Plug Type :ø5.5 (mm)
    Output :
    19.5 V DC, A, 180 W
    Input :
  • Dimensions
    Tablet:
    390 x 266 x 23.5 mm (WxDxH)
  • Weight
    2.2 kg with Battery
GL502VM_2.1.pdf
Hi ThienBui.
I have the same problem with Zeeshan in the post above...
My motherboard GL502VMK before started without image; after reprogramming the BIOS the laptop returned to display image but when I check the GTX 1060 graphics in the device manager it is not present.
If I enable the option to see hidden devices it appears as watermark, but even trying to reinstall the driver it does not become active.
Can you help me with this problem?
Thanks in advance.
Best regards.
Original bios have problem what ? and send i check
Hi Thien.
I know, it's bad news, but I dont have the original dump bios... :fou: (fou)
Is there no solution?
I have tried a few main bios in combination with EC bios and i dont have successful...
The initial problem with the laptop was to start with no image for the LCD.
After programming main bios I already have image, but the GTX1060 graphics is not detected ...
Thanks
Hi Thien.
Thanks
send photo full motherboard i check info
Hi Thien.
First of all, thank you for your attention.
GTX 1060 remains disabled (photo attached).
Any other solution?
Should I test this main bios with some specific EC bios?
Thanks
Good morning, Thien.
Attempting to install the driver, it displays an error message saying that the hardware was not found.
However I tried those bios above clear Rui Fortunato, and the problem continues (hidden / missing GTX graphics).
The GPU heats up, so it has power ... I really think it's a bios problem
Good morning,
I got the extact same problem, the graphic card appears as microsoft basic graphic card, i checked the hardware id and it's the nvidia card and dont let me install the driver.
Is there anything related to this IC BIOS located next to the GPU? (check photo).
I just programmed the bios 8MB and 1MB next to the HDD SSD.
I send the 1MB bios dump that is near to GPU.
25Q80EWNIG.BIN
Hi Thien
I tested with the bios:
MAIN you suggested
ASUS FX60VM GL502VM REV 2.1 i7 DIS.BIN.zip
File size:5.5 MB
View Tracker
And
OTP near GPU you suggested
ASUS GL502VM W25Q80(8K BIT OTP.BIN
File size:1 MB
View Tracker
And
NEAR MAIN / SSD
25Q80DVSIG
Dump client board bios.
And now the pc turns on, I hear the windows start, but I have no image for LCD or HDMI
Hi Thien
MAIN you suggested
File size:5.5 MB
View Tracker
And
File size:1 MB
View Tracker
And
NEAR MAIN / SSD
25Q80DVSIG
check chip GPU and LCD, Cable....
With the other bios the equipment have image for the lcd ...
Initial fault notebook start without image.
After programing to MAIN it started with image, but with the GTX graphic disabled.
send one photo drive manager i check, and photo full motherboard
