Ask Apple M1 and T2 solution "Permanent Unlock" for technicians is available
Question & Answer Forums
Intel Cpu.I have T203 activation lock assistant and u-bos2 programmer.
It does not unlock as described. After the dfu mod, can not os is install. It passes the initial email verification and gives an error 203 - no connection to the server
If you Restore Macbook or if install New Monterey os then you cant unlock.For all procedure you need to check jailbreak work or not.
I'm looking for a hardware solution to the lockup with a clean bios or even a T2 replacement, I think I'd be fine.
