Unlock Use SCBO unlock Apple T2 chip
EFI iCloud Firmware SCBO
1: Get HASH CODE
Press and hold when you see the lock screen:
Next:
Press Simultaneously:
2: Instructions for creating SCBO bootable USB
cp ~/Desktop/SCBO.bin /Volumes/Firmware/.SCBO
cp ~/Desktop/SCBO.bin /Volumes/Firmware/._SCBO
Next:
  1. Turn off computer locked.​
  2. Insert the Flash drive into the computer.​
  3. Turn on the computer while pressing and holding the Option key.​
  4. You should see the lock symbol for a moment, and then the computer should restart to the Startup Manager.​
  5. If you still see digit "passcode" lock after these steps at startup, reset the NVRAM by holding down Command-Option-P-R while restarting the computer.​
After EFI is removed use your own Bootable OS X and install it. First installation don't do over WiFi.
You need to have USB and other apple computer available to create USB
This is just an article that introduces the steps to follow, in order to successfully unlock you need to pay more. :p
Hi its permanant unlock service no bypass
You need send me serial number
Will unlock 1-30 mint from Apple server
Now no need bypass
Send serial i will give you price
Hi Imran, (1) what inbox or private message should I send the serial num please? (2) Are you able to unlock and pay you if it works first please? You will 100 be paid. I just want to make sure it works. Please reach out to me
Hi its work 100%.
