Ask Apple M1 and T2 solution "Permanent Unlock" for technicians is available
Question & Answer Forums
Intel Cpu.I have T203 activation lock assistant and u-bos2 programmer.
It does not unlock as described. After the dfu mod, can not os is install. It passes the initial email verification and gives an error 203 - no connection to the server
If you Restore Macbook or if install New Monterey os then you cant unlock.For all procedure you need to check jailbreak work or not.
