Unlock Xóa mật khẩu bios Toshia một số model mới
5.00 star(s) 1 Vote
CEO
Dec 13, 2013
77,752
5,381
VinaFix
vinafix.com
SatelliteP100 & Satellite Pro P100
Open Wi-FiCover
Remove Mini Card Wi-Fi card
Locate & Short Out JP8 for 5 Seconds
Remove short and turn on
NO BOOT
Press & Hold Power button to turn off
Turn on again & password is cleared
SatelliteL10, L20, L30 & Satellite Pro L20
Open Wi-FiCover
Locate & Short Out JP1 for 15 Seconds (Satellite L10)
Satellite L20/Pro L20 short out G1
SatelliteM100 & Tecra A6
Open MemoryCover
Remove Memory
Remove Black plastic insulation
Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite:17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70,A80, M40X, M50,M60, M70, M100
TecraA3/S2, A5, A6
The jumper isalways located under or near the memory modules
Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOSCLR1 (M100 & A6)
Satellite,Equium A100 & Tecra A7
1.Remove Stripcover
2.Remove 2 x K/B screws
3.Move K/B Unit up but don’t disconnect
4.Release & Remove Mini Card Wi-Fi Card
5.Locate & short C88 Pin 1 & 2 together
6.Power on Machine while still shorting Pin 1 & 2
7.As soon as the Toshiba logo appears, remove short
8.If machine boots, Password has been removed
Satellite A100 (PSAA2A-02C01N)
1.RemoveMemory Cover from base of machine
2.Release & remove right side Memory Module
3.Lift black plastic insulation
4.Locate & short PAD500 Pin 1 & 2 together
5.Power on machine while still shorting Pin 1 & 2
6.As soon as the TOSHIBA logo appears, remove short
7.If machine boots, password has been removed
TECRA A4 & Satellite M40
1.Open modem& Wi-Fi card cover
2.Remove mini PCI Wi-Fi card
3.Lift up black plastic
4.Locate & short C738 Pin 1 & 2 together
TECRA S1
1.Open palmrest cover
4.Locate & short C5071 Pin 1 & 2 together
TE-2300
1.Remove 2 xB12 screws from bottom of system
2.Remove strip cover
3.Remove keyboard screws 1 x B2.5 & 1 x SF4
4.Remove 1 x 4mm screw & Wi-Fi cover
5.Remove mini PCI Wi-Fi card if fitted
6.Locate & short points as shown in picture below
7.Power on machine while still shorting points
8.Short for 5 seconds
9.Nothing will appear on the screen
10.Turn system off holding down power button
11.Password is now removed
Satellite A60
1.Open Wi-Fislot cover
2.Lift up black plastic
3.Locate & short C561 Pin 1 & 2 together
4.Power on machine while still shorting Pin 1 & 2
5.As soon as the TOSHIBA logo appears, remove short
6.If machine boots, password has been removed.
Satellite Pro L40
1.Open Wi-Fi & RAM slot cover
2. Locate JRST1 Between Ram and Wifi slot
3.short JRST1 AND TURN ON SYSTEM.
4. Short for 15 seconds.
5. system is shutdown automatic.
6.turn on the system password is removed.
  • Locate G1 or c513 and G2 or C514 to reset Bios
  • In some models it will be B500 under ram cover
  • Works on satellite L650.
  • Importantly, the “B500″. For better contact, welded a small copper wire between the two plots “B500″.
  • Place one strip of memory start.
  • Display the first page of the bios and then extinction of the laptop alone.
  • Remove the small copper wire and put the remaining memory.
  • Restart and that’s OK.
Toshiba Satellite L700/750
  • open ramcover
  • locate G1 for bios reset
  • open ramcover
  • locate J2 for bios reset
Toshiba Satalite C850
  • Open ram cover
  • locatae B500 short it for a minute
  • restart your laptop with bios password.
5.00 star(s) 1 Vote
