Asus X555LD boardview and BIOS
X555LD 2.0,60NB0640-MB1340
VM510LJ X555LD REV3.6 I7-5500U NVIDIA 920M.504.bin
ECROM
X555LD lx-5xxxxU ECROM.bin
X555LD lx-4xxxxU ECROM.bin
ASUS X555LD REV1.2.pdf
ASUS X555LD REV2.0.pdf
ASUS X555LD REV3.1.pdf
ASUS X555LD REV3.3.pdf
its not chipset issue , the problem is on the socket were the hdd board attach on the board is pretty common and we change does ports at least 10 per week , so main problem on this board usually for NOI HDD NO SOUND (socket attached on the motherboard that connect the hdd board ) there is your problem if you chek you will see you got no continuity from the insyde pin of the socket with the solder legs on the outside of the connector . somethimes the HDD BOARD ALSO IS DAMAGED , so first chek continuity on the socket , then go further
tien , i got the x555ld 3.6 but i got the 920M video card on it , so wich is the best bios for this motherboard , cpu i7 and 920M gpu ?
