Warning!! - machine is not in committed state!
How to fix?
Warning machine is not in committed state
Warning: This BIOS is Not for Production Use.
Downloads AMTBrand tool
Brand11:
1. Copy folder Brand11 to the root of the USB key formatted as FAT32.
*** Your USB key should have less than 40 folders and files in the root. ***
2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode
-> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
3. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
-> Bootx64.efi -> Press enter to run startup.nsh
4. Follow menu to commit AMT and AT.
Chose 1 to commit VPRO with AT, or 3 to commit Non-VPRO with AT
5. Press 9 and then Enter key to lock descriptor and reboot the machine.
6. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
-> Bootx64.efi. You should see the message "Pass!!! This machine is configured"
7. Reboot to F10 and disable EFI boot mode. Done.
Brand12:
1. Copy folder Brand12 to the root of the USB key formatted as FAT16/FAT32.
2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode -> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand12 -> Bootx64.efi.
Brand13:
1. Copy folder Brand13 to the root of the USB key formatted as FAT16/FAT32.
2. Goes to F10 -> System Configuration -> Boot options -> Boot Mode -> Choose "UEFI Hybrid" mode -> Save and exit.
3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand13 -> Bootx64.efi.
HP_tools.zip
Today i try i have a laptop hp 640 g1 working fine when install intel 4600 graphic driver restart hp logo show and display gone black screen laptop running external working good i try clean me region when start laptop show (machine-is-not-in-committed-state) i think is the problem is me region how to remove this error and problem still have.i try many driver same problem any suggestion about this problem.
hello imranromi, I have same problem, when I using brand14 I have error "it can not be commited again, failed to commit" I didn't find solution maybe anyone who help me. 9db01159c4e2cd199ff6fd726c645e60.jpg[Broken External Image]:https://ibb.co/nq3PCn
Chào ThienBui !
Xin bạn giúp đỡ
Mình sử dung HP Elitebook 2540p core i7 640LM vừa mới phải thay main.
- Sau khi thay main thợ gắn con bios từ main cũ thì fan không hoạt động khi sử dung pin nên phải sử dung lại con bios main mới đi kèm, thì hoạt động bình thường.
- Xuất hiện lỗi machine is not in committed.
Mong nhận được sự giúp đỡ từ bạn để có thể bỏ đi lỗi warning này.
- Và xin hỏi lỗi này có gây ảnh hưởng đến phần cứng cũng như hiệu năng của máy không
Mình xin cảm ơn !
Chào ThienBui !
Xin bạn giúp đỡ
Mình xin cảm ơn !
Sử dụng bios zin của main đó vẫn bị sao ?, đây chỉ là thông bao thiếu thông tin của máy thôi, ko ảnh hưởng đến tốc độ. Bạn có phải kỹ thuật sửa chưa không ?
Không thưa ThienBui nhưng cái main mới đó không có fan nên sử dung fan của main cũ. thì xuất hiện báo lỗi như vậy.
Cụ thể như sau:
- Thay main mới (chỉ có main và CPU vì là chip dán) nhưng sử dung con bios của main cũ. Fan không hoạt động khi sử dung pin, cắm nguồn fan chạy bình thường.
- báo lỗi thợ, thợ thay con bios đi theo main mới thì Fan hoạt động bình thường, nhưng xuất hiện lỗi machine is not in committed.
Cụ thể như sau:
main mới ko có fan thì tất nhiên rôi nhưng nó ko có liên quan gì đến ( ko có fan phải lấy thêm BIOS từ Main cũ) main nào thì sử dụng bios của main ấy trừ khi nó bị lỗi.
Main mới ko có thông tin máy cung ko có gì lạ. Mình có thể fix lỗi này nếu bạn gửi cho mình hai file bios cũ và mới, nhưng bạn cần phải biết nạp bios, và mua một tài khoản VIP để có thể tải về file bios. :(
Bạn có thể inbox mình nếu muốn hỏi thêm.
https://vinafix.com/conversations/
Đầu tiên mình gửi lời cảm ơn vì sự nhiệt tình của bạn.
- Nạp Bios cần phải có có công cụ (thợ bảo vậy) chứ không phải qua phần mềm.
còn nều update bios qua file trên trang chủ của HP thì mình đã từng làm.
Hệ thống mình nạp vip hết 800.000 quả là không nhỏ.
Mình chỉ có một thắc mắc là tại sao khi thay con Bios của main cũ thì không có thông báo nhưng fan lại không hoạt động.
- Còn khi sử dung bios đồng bộ theo main mới thì lại không có thông tin.
Xin hãy giải đáp giúp mình.
- VIP thấp nhất là 300, bạn ko phải thợ nếu có nhu cầu thì mình có thể giúp nhưng vẫn phải mang máy đến thợ sửa chữa phần cứng để có máy nạp lại BIOS, ko phải update.
BIOS có trao đổi dữ liệu với các chipset trên motherboard đặc biệt là những CPU dán sau này, khi thay đổi BIOS hay chipset đều phát sinh một số lỗi về thông tin và lệnh điều khiển...
- Main mới ko có thông tin hoặc thông ko đúng cúng ko có gì lạ, main laptop ko giống nhứ Desktop no ko đc bán chính thông ra thị trường, phần lớn từ nhiều nguồn lung tung mà có... phát sinh lỗi cúng ko lạ nhưng nếu bạn thay main đúng chỗ có kỹ thuật chuyên phần cứng họ sẽ biết hỗ trợ bạn.
Vâng. Vậy xin hãy chỉ cho tôi những điều mình cần phải làm là gì.
- Lấy thông Bios cũ và mới như nào.
- Chi phí nạp Bios cho modern này là bao nhiêu.
Xin hãy hướng dẫn chi tiết vì mình không phải dân máy tính. Chỉ đọc kiến thức trên mạng do có chút vốn tiếng anh.
Mình chỉ có thể giúp bạn khi cung cấp bios như nói ở trên, còn làm thế nào thì mình ko hướng dẫn đc, cần biết và có máy móc đàng hoàng, phần cứng ko giống như phần mềm nói sơ sơ là ai cúng làm đc. Thường nếu bạn thay main đúng chỗ sửa chữa laptop thì họ phải biết vẫn đề này để hỗ trợ bạn.
Hello, got an early sample notebook hp pro x2 612 g2 with test bios ( attached )
would like to update to normal and fix - not in committed state
how do i cancel bios signature check and which brand should i use for dmi ( looks like non from 11-16 works and mpm is not unlocked) ?
also - will i7-7y75 (engineering sample) - will work with usual bios ?
P86_8031.bin.zip
yes, you need buy one VIP and get support
Account Upgrades
ad ơi phá lại giúp mình với. con này nạp vào được rồi nhưng nó báo machine is not in committed state, làm cả 3 cách trên rồi nhưng không được
bios gốc làm sao có lỗi đó được. file có password phải zin của nó không ?
unlock.bin.zip
