Thinkpad x1 cacbon nano ZS1TL-7 19796-1
ZS1TL-7
19796-1
19796-1.brd.zip
Lenovo ThinkPad X1 Nano Gen 2 Wistron 19796-3 X1 Nano.pdf
Lenovo ThinkPad X1 Nano Gen 2 19796-1.brd
Good afternoon, @ThienBui
This PC had a firmware update through Windows update and now it turns on with an image but a bios error appears... The PC tries to recover but is unable to reverse the bad update.
I've already tried with the bios from the Vinafix post and with some rebuilt by you (without success).
Can you analyze my source BIOS and fix the problem?
Thanks.
Thanks.
It didn't work...
Now the PC won't turn on.
If you remove the battery and only use a charger, there is no current consumption (it will not turn on).
If the battery is connected, when we connect the charger, the power LED flashes white and then the battery is consumed with an orange LED.
Can you check again, please.
Thanks.
It didn't work...
Thanks.
i can not check from bios and i think can harwdare have problem
With the original BIOS, the PC turns on with the image, but presents a BIOS update error and tries to reverse the process, but without success...
How could it be a hardware problem?
