I have tried all the files above, none of them match, all have no power. but if you use the old bios it can make errors and it will just go blank.another file on top Available
next check hardwareI have tried all the files above, none of them match, all have no power. but if you use the old bios it can make errors and it will just go blank.
Can you confirm my bios again, I'm sure the problem is only in the bios. because using the original bios it can be wrong but no display when you press enter the text appears as in the photo, after that it goes blank again.next check hardware
If you are sure the error is from the BIOS then download another BIOS for programming I have nothing to help edit from the bios with this errorCan you confirm my bios again, I'm sure the problem is only in the bios. because using the original bios it can be wrong but no display when you press enter the text appears as in the photo, after that it goes blank again.
Lenovo ThinkPad X1 Nano Gen 2 Wistron
19796-3 X1 Nano
help me
no display after update bios
try more bios hereno power
i try also no powertry more bios here
Thinkpad x1 cacbon nano ZS1TL-7 19796-1
Thinkpad x1 cacbon nano ZS1TL-7 19796-1 BIOS 19796-1.brd.zip Lenovo ThinkPad X1 Nano Gen 2 Wistron 19796-3 X1 Nano.pdf Lenovo ThinkPad X1 Nano Gen 2 19796-1.brdvinafix.com
help to rebuildi try also no power
help to rebuild
one time display logo ok booting blank display
please rebuld..........
i can't fix it from biosssd error other ssd i try but same no pan drive boot bios update not set evry time update...... update...
please helf .......my frands.........
admin clae me dùm khong len hinh ZS1TL-9 19796-3
