BIOS ThinkPad E490, E490s, E590
I Tried Multiple Clear Me Bios from this Forum
why try Multiple BIOS non clearme ?
all BIOS clearme has its original file
If you want to fix the above error, you need to find the BIOS that does not clearme work.
and Original bios error what ?
I don't have the original bios bin file, the original error was no display. I tried multiple bios bin file here I found one working but there is no wifi card detected and m.2 SSD error also
if a change the bios chip and try other bin files here it will work?
It's still a matter of BIOS and hardware
As a technique, you need to determine where the problem begins,
Engineering is not just about programming bios
I'm sure the problem is with the bios because the laptop was working fine before until the bios were updated, and maybe in the middle of the bios update was interrupted by the end-user.
I'm sure the problem is with the bios because the laptop was working fine before until the bios were updated, and maybe in the middle of the bios update was interrupted by the end-user.you
you have save Original BIOS ? send I help check
Hola tengo problemas de deteccion de disco duro en un portatil E490. Placa NM-B911 Revision 1.0. Indica la falla "Error 2101: Detection error on storage device0 (M.2 Main Slot) "; el equipo lo trabaje por bios, luego de colocar el bios el equipo no reconocia ninguno de los dos discos ni el M.2 ni el sata. Actualice el Bios desde un windows live y me empezo a reconocer el disco duro sata, pero el M.2 aun me sigue apareciendo el error supongo que podria tratarse de un problema de bios. me puedes ayudar? incluyo los bios main, ademas de la imagen de la falla que te comento. Gracias.-
M2 is very prone to errors when the bios is programmed, please suggest that customers use a sata drive or you need to find a way to fix it, can't check from bios
