SURFACE PRO 6.BIN
so the BIOS you sent is not the original BIOS and if there is no original BIOS the touch will not worksir display working,,touch not working
if clearme touch won't work i think you need to try another bios first1
I Used another bios but toch is not working plese clear me urgentif clearme touch won't work i think you need to try another bios first
yes for Surface if clearme or using other BIOS the touch won't work, please keep in mind I won't repeat it next timeI Used another bios but toch is not working plese clear me urgent
sir my old bios stuck logo,,,you give me build bios after check windows open properly buy touch screen not workingso the BIOS you sent is not the original BIOS and if there is no original BIOS the touch will not work
Is the BIOS you sent original? provide s/n on the case i checksir my old bios stuck logo,,,you give me build bios after check windows open properly buy touch screen not working
if you use other BIOS or clearme touch will not worktouch not working
send one photo s/n above case I check right Original biostouch not working original
anh Thiện fix em file này kích tắt ạ. em nạp file của anh lên rồi ạ.
nhưng ko cảm ứng
shows 2 seconds logo and OFF
1796 256
044930192458
giúp đệ với Huynh ới @ThienBuibuild giúp với huynh ,lên logo tắt ,đã chép 1 số file nhưng boot chậm ,kg cảm ung
tình trạng giống file gốc hả ?file này lên tăt SH ơi ,giup với
