Surface Pro 5 1796
Surface Pro 5 1796 ok.BIN
You need to focus on fixing one PC to work properly before thinking about other PCsokay, how can we proceed to do this? I have about 4 devices with the bios lost/deleted
okay, let me see if I can organize myself with the deleted/lost bios and the ones I currently have and I will respond to you and make the first payment, thank you very much ThienBuiYou need to focus on fixing one PC to work properly before thinking about other PCs
link payment
doneYou need to focus on fixing one PC to work properly before thinking about other PCs
link payment
send me bios file touch not workingdone
hi Thien,send me bios file touch not working
I can only provide you with the n/s, I have more than 8 surface devices with this problemhi Thien,
I already told you that it was deleted, I didn't know that I needed the original bios for the surfaces at the beginning so I never saved the original bios
You need to install another BIOS program and check the laptop is working then I will help fix the touch screen, I don't need s/nI can only provide you with the n/s, I have more than 8 surface devices with this problem
Now if I understand you, okay, I'll do thatYou need to install another BIOS program and check the laptop is working then I will help fix the touch screen, I don't need s/n
Surface Pro 5 1796
plz remove password
If the original bios itself doesn't work with the touch then I can't fix ithi Thien, Original Bios chip foundet XD, please fix, no touch, Pro 5 1796......thanks
Hi Thien, It is the original bios, and it stopped working after some update, can you please try it at least, now that I finally found this original bios, thank you very muchIf the original bios itself doesn't work with the touch then I can't fix it
Have you programmed another BIOS?Hi Thien, It is the original bios, and it stopped working after some update, can you please try it at least, now that I finally found this original bios, thank you very much
This bios was never edited or modified, it is the original data
What do you mean after the update the touch screen doesn't work?This bios was never edited or modified, it is the original data
