HP SMC.bin file generator ?
I don't have the tool mentioned and i m not enough hardware specialist for that. Does that mean my situation won't change and i won't be able to use my laptop ?
I'm an IT tech so a bit familiar with IT but not sure what you mean about : programming bios
This is a hardware issue that needs to know welding and BIOS programming, I suggest you bring your computer to a specialist store for support.
I understand, I am asking for help in unblocking the MPM module. I want to make changes to the serial number, etc.
I am sending two batches from both SPI chips, because I do not know which one you need.
send s/n you wnat replace I help
This message appears at startup. I uploaded the bios from the vinafix forum, because the original was damaged. I also have both ripped original ripples as if they were needed.
Below are all the necessary details.
so you need to program another BIOS with full DMI information
I don't have any other BIOS batch for this model. The current one I downloaded from the Vinafix forum. You can not unlock me so that I fill in the missing DMI and change it to the correct serial number.
