Ask Need firmware for XY-W58CDT9-AV7 with LM215WF3-SLA1 or firmware with full options menu
Question & Answer Forums
joeywrench
Hello, I need the correct firmware (.bin) for this LCD controller board.
Board: XY-W58CDT9-AV7
Panel: LM215WF3-SLA1
Mode: Dual-channel 8-bit LVDS, 1920x1080
If anyone has the correct SPI flash .bin file, please share it. Thank you!
你好,我需要这个主板的固件(.bin 文件)。
主板型号:XY-W58CDT9-AV7
屏幕型号:LM215WF3-SLA1
模式:双路 8bit LVDS,1920×1080
请发送对应的 SPI 刷写固件。谢谢!
If the exact LM215WF3‑SLA1 firmware is not available, any working 512KB TSUMV58 / V58 firmware for the XY‑W58CDT9‑AV7 board (or similar V58 HDMI→LVDS boards using MX25L4006E) would also be very helpful.
I am mainly looking for a firmware that exposes more LVDS configuration options in the OSD menu (mapping, 6/8‑bit, JEIDA/VESA, dual‑channel, etc.). Even a generic or engineering version is fine.
Thank you to anyone who can share any compatible 512KB V58 firmware.
如果没有专门适配 LM215WF3‑SLA1 的固件,也可以提供任何适用于
XY‑W58CDT9‑AV7(或类似 V58 HDMI→LVDS 主板,使用 MX25L4006E 芯片)
的 512KB TSUMV58 / V58 固件。
主要希望固件能在 OSD 菜单中提供更多 LVDS 设置选项(映射、6/8bit、
JEIDA/VESA、双通道等)。即使是通用版或工程版固件也可以。
非常感谢任何可以分享的 512KB V58 固件。
