Asus N551JM REV.2.0 N15P-GX-A2
N551JM REV.2.0 N15P-GX-A2 BIOS
IT8585E
N551JM KB_pins=30 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24
ASUS_N551JM_N551JM photo
Hello.
I have a Asus N551JM with N16P-GX-A2 that turns on immediately when 19V are applied. goes to 450mA and 15 secs after fan goes to full speed at 550ma.
No image and no USB port activity.
All tensions and signals seem to be present. PM_SYSPWROK present, 3.39V
CPU vcore and GPU vcore OK. 5V, 3.3V etc all OK
Board specs:
n551jm-rev20
n16pgxa2
vram8-sr15g-ite8585efxa
W25Q64(8K BIT OTP)
Can it be a crazy EC that needs to be reprogrammed?
Bios should be OK right?
Here the original Bios dump.
Thank you!
Hello.
Board specs:
n551jm-rev20
n16pgxa2
W25Q64(8K BIT OTP)
Thank you!
yes IT8585E have Programming.
i think try one BIOS new before where Programming EC.
Hi!
Yes, Ive tested it with the Bios file
Asus n551-n551jm-rev20-n16pgxa2-vram8-sr15g-ite8585efxa-W25Q64(8K BIT OTP).BIN
same thing.board acts the same.
Do you have EC file for this model?
thank you
update on top you.
Thank you
Now that I have the programmer for this, but I still have a small problem.
Since the MB starts itself when plugged in, I cannot program the chip while its running.
I see 3 or 4 pins with 3.3V on the power button connector, dont know which one to short to ground...
Should I power the IT8585E directly with 3.3V at PIN 11 VCC and should be good?
Ive mapped the KB connections for the Vertyanov if anyone needs it just copy this to file MB connection ITE.txt
Thanks for any advice!
Thank you
check battrey CMOS
but laptop auto on where connect power ?
Yes, when I inject 19V in DCIN it turns on automatically.see my initial description
All voltages and signals seem to be present. PM_SYSPWROK present, 3.39V
I need an advice what could be the issue. i have that N551JM with N16P-GX-A2 and turns on and stuck on logo doesnt go further. i have changed the bios chip with another asus laptop i have here and it still does the same . i have reprogram 5 bios file you have here and some of them has black screen and some same issue doesnt go further than rog logo
you need check hardware, Special GPU chip if available
