Ask msi ms-1541 rev 1.0 ene 9028q c
Question & Answer Forums
Sławomir
Active Member
VIP PRO
Hello. I have a problem. I have an SVOD 4 and a ZIF-128 adapter for IO BIOS chips. I have an MSI with a damaged KBC BGA chip. I can't program it either through the ZIF-128 socket or the keyboard connector. I have no idea why it doesn't recognize any ENE KB9028Q chips. What could be the issue? Are these sockets not working? What am I doing wrong?
MS-1541.10F.bin.zip
After uploading this batch, will the IO system program itself? If I understand correctly, it's MSI.
I have a damaged kbc zif 128 bga ene chip and I can't program it, I have svod 4 and I have a zif adapter but it doesn't help, I can't connect to the board via the keyboard connector, why is this happening?
How to update?
Hello. I have a damaged KBC ENE KB9828G C chip, shorted, in an MSI MS-1541 Rev 1.0 ZIF 128 BGA ENE laptop. I can't program it. I have SVOD 4 and a ZIF adapter, but that doesn't help. I can't connect to the motherboard via the keyboard connector. Why is this happening? I have a set with a ZIF BGA adapter. Please tell me if it's the programmer's fault or if the chip is not supported. I've already bought 10 different units from different sellers.
