MSI GE63 RAIDER RGB 8RF MS-16P5 Coffelake 8th MS-16P51
MSI GE63 RAIDER RGB 8RF MS-16P5, MS-16P51 Coffelake 8th BIOS
MS-16P51
MSI MS-16P51 MS-17C5 photo Discrete
GP63 LEOPARD 8RE
MSI GP63 LEOPARD 8RE MS-16P5_MS-17C5 Rev 0A.pdf
Thanks for clear me, display late solved it,
but I have another problem with this bios. The sound only works from the headphone jack, the speakers do not work. With the original bios which is password protected, the speakers are functional. So would it be possible tounpass the original bios with password?
audio you need check driver and chip manage audio.
I know. The audio chip is fully functional, with the original bios with password.
There was no sound with the bios without a password, only from the headphone jack,
I tried to install various audio chip drivers, even the original from the msi website, nothing helped.
I'm not sure if the bios without a password is 100% designed for my mainboard.
Please:
Would it be possible to remove the password from the original bios?
Please:
have password how you know audio work ?
Please returm old bios and make one video I check
Yes,
this is video with original bios with password.
Bios password is only if i need enter bios screen (DEL key)
Audio is heard in the video, I turn on the narrator and the audio works from the speaker, no more need to know the sound is functional with this bios.
The password is the first time because I press the DEL key to get to the bios and it is password protected, after the next power on I do not press the Del key and so the system starts to boot.
With the second bios (before clear me and after clear me) the sound only works from the headphone jack, it does not switch to the speakers even after the headphones are disconnected. The audio driver did not solve this, tested on several different operating systems. Changing the audio settings on the system also does not solve it.
So I need to unpass the original bios with the password or use another bios where everything will work ...
but it is BIOS you request clear me, you need check all ok before when request fix late display.
when it not work good like before that you need try BIOS other.
