BIOS Microsoft Surface Pro 7 1866 Schematics boardview BIOS
Surface Pro 7 1866
BIOS Gen 10th
ALAMA BoardView.pdf
JALAMA.pdf
SSD
That shows that the BIOS you sent is not the original bios or it is corrupted
Microsoft Surface 1868
This original file works but gives errors during Windows installation
The ssd was replaced and the problem was not solved. Can you clear it?
I helped build this bios above, I need to know if it is the original BIOS of that computer?
Yes, it is 100% original
But after building it does not see the ssd
above you say no signal
but below say winodws install error
Where is the correct information?
I'm sorry
At first I said there was no signal. I was wrong in describing the problem
The main and correct problem is that it gives an error message during Windows installation
