BIOS M1603Q M1403QA
M1603Q M1403QA
M1403qa photo
M1403QA KB_pins=30 LEFT DOWN 08MM PD0=2 PD1=11 PD2=16 PD3=8 PD4=17 PD5=15 PD6=19 PD7=1 BUSY=5 STB=13 AFD=3 INIT=10 SLIN=12 KSI4=9 KSI5=7 CHIP=IT5125VG-128
Отключите оперативную память на моем биосе, не шлите мне пожалуйста биос другого автора, делайте отключение на моем биосе.
Спасибо!
This is the BIOS that has been edited to disable the onboard RAM. The laptop initially bluescreened because the onboard RAM was problematic. I reprogrammed the BIOS with the RAM disable file, but it didn't appear. I've installed additional RAM but it still doesn't appear. If I reprogram it with the original BIOS, the additional RAM is detected in the BIOS. Is there another way, sir?
thank you
