Ask LENOVO THINKBOOK 15 G2 ARE GLV3B LA-K062P REV:1A
Question & Answer Forums
PcHouse
Active Member
VIP PRO
Device is getting all tensions correctly but doesn't started, power bottom light switch on and off after a wile...
Tried a different BIOS from another revision of board and it started the device, but doesn't boot any system, neither the original or external ones like linux….
Could you FIX the original bios please ?
Thanks.
Thanks.
AMD.zip
The same issue still happening, when the device starts the system it crashes and restart everything... it's happening with the original system and also external systems... like linux or windows live.
I also tried different rams to see if that could be the issue, but nothing worked...
